A Week in Aros
A Week in Aros
Messaggioda sabbate » ven mag 01, 2015 9:26 pm
Aggiornamenti di stato da parte dei programmatori :felice:
Week of April 6th:
- Notification of MUIA_Listview_ClickColumn in certain condition is now fixed. (neil)
- MUIM_List_TestPos now treats the last column as extending to the right-hand edge of the list. (neil)
- Development of AROS kernel for RaspberryPi port continues (mschulz, Kalamatee)
- Fix for manipulating event handlers in Listview MUI class has been implemented (neil)
- Configuration file for AROS RaspberryPi kernel is now generated during build (Kalamatee)
- Kernel area of RaspberryPi port is now memory-protected against writes (mschulz)
- RaspberryPi port of AROS now use TLSF memory menager (mschulz)
- Work on porting AROSPDF continues (mazze)
- A separate download web-page for snapshot builds compatible with ABIV1 is now available (mazze)
- ABIV0 and ABIV1 download packages are now hosted on separate download pages (neil, deadwood)
- RaspberryPi AROS kernel no longer enters supervisor mode for data synchronization under certain conditions (mschulz)
- Implementation of cache control functions for ARM kernels has been started (mschulz)
- Implementation of translation between virtual and physical addresses functions for ARM kernels has been started (mschulz)
- AROS kernel for ARM architecture is now able to detect the number of existing process cores (Kalamatee)
- ZuneARC is now part of AROS ports repository (mazze)
sabbate
Re: A Week in Aros
Messaggioda sabbate » ven mag 01, 2015 9:27 pm
Week of April 13th:
- VisualBoyAdvanced emulator is now part of AROS ports repositor (mazze)
- Procedure for detecting number of existing processor cores improved (Kamalatee)
- Work on USB driver for RaspberryPi port resumes (Kalamatee)
- A memory corruption bug in GrafX2 has been fixed (mazze)
- Reading status registers in sdcard.device has been improved (mschulz)
- Problem which could cause trashing of kernel area for RaspberryPi port has been fixed (Kalamatee)
- Lunapaint now builds as part of AROS ports repository (mazze)
- 64-bit shift operations for ARM platform are now implemented (mschulz)
- Child objects added to disabled MUI Group object are now also disabled (neil)
- List and Scrollbar objects are no longer wrapped into internal Group object in Listview (neil)
- Code for aligned allocations in TLSF now has better checks agaist null allocations (deadwood)
- Builds of ABIV1 ports repository for m68k and i386 are now available on www.aros.org, ABIV1 snaphots section (mazze)
- Switching between user and system mode in ARM kernel interrupt handling has been fixed (mschulz)
- OpenGL software renderer for m68k AROS no longer shows wrong colors (wawa)
- Integer to double operations for ARM platform are now implemented (mschulz)
- ARM kernel interrupt handling has been improved and simplified (mschulz)
- Builds of ABIV0 ports repository for i386 and armhf are now available (deadwood)
- Interrupt acknowledgment for VBlank emulation and timer now works correctly in ARM kernel (mschulz)
- Idle task routine in ARM kernel is now implemented (mschulz)
sabbate
Re: A Week in Aros
Week of April 20th:
- Pendisplay MUI class now correctly handles pen data and issues notifications when needed (neil)
- AROS website now contains section on testing specification (neil)
- Additional RaspberryPi 2 CPU cores are now woken up and await for interrupts (mschulz)
- Colorfield MUI class now correctly initializes and sends notifications (neil)
- MUI_PenSpec structure is now corrected to be source compatible (neil)
- 64bit integer to double conversion for ARM platform is now available (mschulz)
- Work on porting APDF continues (mazze)
- "Ignore Workbench/Shell" option in Snoopy now works correctly (mazze)
- State of VFP registers is now correctly saved and restored on ARM platform (mschulz)
sabbate
Re: A Week in Aros
Messaggioda sabbate » mer mag 06, 2015 1:17 am
Week of April 27th:
- Work on per CPU core of handling of SysBase for AROS ARM kernel started (Kalamatee)
- Work on task scheduler for AROS ARM kernel started (Kalamatee)
- Accessing the current task has been cleaned up in exec.library codes (mschulz)
- task.resource module has been introduced to allow access to AROS-specific task information (Kalamatee)
- C:TaskList has been updated to use task.resource (Kalamatee)
- task.resource has been extended with functionality of querying task lists (Kalamatee)
- AROS ARM kernel now records start time and running time of task (Kalamatee)
- Support for spinlock primitive has been added to AROS kernel (Kalamatee)
- Basic support for Inter-processor Interrupts implemented in AROS ARM kernel (mschulz)
- AMR-specific implementation of spinlocks has been added to AROS kernel (mschulz)
- AHCI driver no longer constantly mounts/unmounts the medium (dizzyofcrn)
- Crashes and memory leaks have been fixed in AROS Vim port (mazze)
- xxd tool is now build together with Vim (mazze)
sabbate
Re: A Week in Aros
Messaggioda sabbate » mar mag 12, 2015 7:17 pm
Week of May 4th:
- Work on Inter-processor Interrupts in AROS ARM kernel continues (Kalamatee)
- Memory pool semaphore protection now works correctly when using TLSF mememory manager (deadwood)
- Task scheduler in ARM kernel updated to correctly move running/ready tasks (Kalamatee)
- Idle tasks are now started on additional CPU cores in ARM kernel (Kalamatee)
- Work on USB3.0 support continues (dizzyofcrn)
- SDL application will no longer exit with unfreed signals (mazze)
- ScreenRecorder tool now has german catalog (polluks)
sabbate
Re: A Week in Aros
Messaggioda sabbate » gio lug 16, 2015 6:21 pm
Week of May 11th:
- Work on having higher priority tasks yield when spinning started (Kalamatee)
- Tasks which are spinning are moved to separate list now in AROS ARM kernel (Kalamatee)
- Work on scheduler of ARM kernel continues (Kalamatee)
- Testing specification for String class added (neil)
- MUI String class now does a display-beep in case of rejected character (neil)
- MUIA_String_BufferPos attriute of MUI String class is now initializable (neil)
- MUIA_String_Format attribute of MUI String class is now gettable (neil)
- Rocks and Diamonds game is now part of ports repository of AROS (mazze)
- MUI Aboutbox custom class now displays the build information (deadwood)
- UI bug in Poseidon pop up window fixed (Kalamatee)
- Handling of scheduling flags has been made mutli-core aware (Kalamatee)
sabbate
Re: A Week in Aros
Messaggioda sabbate » gio lug 16, 2015 6:27 pm
Week of May 18th:
- Regression in CPU cache handling impacting at least AGP and USB on i386 has been fixed (neil)
- A performance regression in IntelGMA driver has been fixed (neil)
- Work on per CPU task handling for AROS ARM kernel continue (Kalamatee)
- Handling of secret text in MUI String class has been improved (neil)
- Handling of partitions list in HDToolBox has been improved (neil)
- FindTask implementation has been extended to look at spinning tasks (Kalamatee)
- A crash in FTManager when selecting anti-aliasing has been fixed (neil)
Week of May 25th:
- Work on per CPU task handling for AROS ARM kernel continue (mschulz)
- C library strtok function has been fixed (neil)
Week of June 1st:
- Keymaps have been update for non breaking space support (polluks)
- Countries have been update for first day of week support (polluks)
- 64-bit AROS again loads Amiga format fonts correctly (jmcmullan)
- fat-handler is now correctly stopping at end of root directory (neil)
- Formatting is now possible with fat-handler (neil)
- Renaming disk is now working correctly in fat-handler (neil)
Week of June 8th:
- fat-handler has been updated to work as ROMable module (jmcmullan)
- MUI Listtree custom class now has more functionality and compatibility (deadwood)
- fat-handler no longer leaks memory in case one of the blocks can't be read (neil)
- Renaming disks is further improved in fat-handler (neil)
Week of June 15th:
- fat-handler now allows multiple volumes with the same name if their creation dates differ (neil)
- fat-handler now distinguishes volumes with unset creation dates (neil)
- slovenia and slovakia country codes are now correct (polluks)
- Listtree MUI class now support context menus and drag&drop (deadwood)
- Support for parallel port communication has been added to m68k port of AROS (jmcmullan)
- Registration of Kickstart memory region has been corrected for x86_64 port of AROS (Kalamatee)
- gdb can now be build as part of cross compiler toolset (jmcmullan)
- C:Info will no longer show unset volume creation dates (neil)
Week of June 22nd:
- Adding a Menuitem MUI object directly to Menustrip now works as in MUI (deadwood)
- Listtree MUI class now correctly notifies about double-click and quiet state (deadwood)
- Memory is now freed in Listtree MUI class at object destruction (deadwood)
- List MUI class no longer crashes when someone tries to create an image without passing the actual image object (deadwood)
- Listtree MUI class no longer crashes when someone tries to delete an non-existing image (deadwood)
- Work on making hostgl.library work again started (Kalamatee)
- HDAudio driver now works correctly on HP Compaq nc6320 laptop (neil)
- Static switching between speakers and headphones at start-up in HDAudio driver has been removed in favor of dynamic switching (neil)
- Output volume control for multiple nodes has been improved in HDAudio driver (neil)
- PCI subsystem now correctly handles situation when an interrupt line assignment to a device has been changed (neil)
Week of June 29th:
- Shell no longer passes junk arguments to scripts (neil)
- Delay in SD card device decreased (mschulz)
- Initial work on storage.resource started (Kalamatee)
- Work on per CPU task handling for AROS continues (Kamalatee)
- Serial and parallel ports devices now load correctly under m68k port of AROS (jmcmullan)
- Passing flags to parallel port device has been fixed (jmcmullan)
- Sorting in NListtree MUI custom class has been fixed (deadwood)
- Listtree MUI class now correctly handling sorting and remove of nodes (deadwood)
- Work on AROS ARM native kernel continues (mschulz)
sabbate
Torna a AROS e compatibili
