PORTING PROGRAMMI [suggerimenti/richieste]
Hello world!
Re: PORTING PROGRAMMI [suggerimenti/richieste]
Messaggioda divina » gio set 24, 2009 3:26 pm
Messaggioda Raffaele » mer nov 04, 2009 12:59 pm
Segnalo questo programma per fare foto panoramiche, partendo da tante foto di base, per poi unirle in un'unico file immagine panoramico:
HUGIN
http://hugin.sourceforge.net/releases/2009.2.0/it.shtml
Ci sono i sorgenti per molte piattaforme, Windows, macOS, Linux...
Ha bisogno di molte dipendenze:
1.wxWindows. Install wxWindows from source or from one of the pre-built wxWindows packages listed above. Ensure that you have the xrc extension installed. For Hugin 0.8.0 and later GLCanvas must be activated.
2.libpano13. Download and build sources from Panotools or install one of the pre-built packages listed above. Note that libpano12 is deprecated, hugin-0.7.0 or later can be built with the newer libpano13.
3.Boost. Some header files are used from the Boost C++ library.
4.Image libraries. libtiff, libjpeg, libpng, OpenEXR and exiv2.
5.GLEW is required for the fast preview, introduced with hugin-0.8.0 or later.
6.GLUT and libGLU are required for hugin-2009.2.0 or later to enable GPU stitching.
7.LaPACK is optional.
8.exiftool. hugin-0.7.0 or later requires the exiftool utility from the Image::ExifTool perl module.
9.make. hugin-0.7.0 or later uses GNU 'make' to oversee the stitching process, i.e. 'make' is required to run Hugin as well as build it.
10.enblend. download enblend. Note that enblend is no longer optional with hugin-0.7.0, enblend must be at least version 3.2 or a current mercurial snapshot.
11.An optional control point generator such as, panomatic or autopano-sift-C.
Alcune ho notato che in Amiga già esistono...
Altre, a portarle, si farebbe solo del bene alla nostra piattaforma, perché così ce le troviamo già pronte per futuri progetti... :annu:
WxWidget, ad esempio funziona nell'ultima versione di X11 Cygnix...
Questo programma lo segnalo come al solito ai nostri programmatori BIG, Tantignone e Andreuccio... :riflette:
Messaggioda MacGyverPPC » mer nov 04, 2009 3:44 pm
Adoro certe applicazioni,sopra tutto se approdano in campo Amiga! :happyboing:
Questo e altri programmi di fotoritocco snelli come ImageFX li userei tutti i santi giorni e ne sarei felicissimo!
Al momento con ImageFX su SAM non riesco a fare un tubo,in confronto ai miracoli e ricorstruzioni di volti,su fotografie mangiate dal tempo,che facevo in maniera semplice e veloce con lo stesso, più DPaint e Photogenics,sul 1200 con 030 e/o 060 e la tavoletta grafica!
La SAM potrebbe tornare a fare la gioia dei grafici se ci fosse (magari alcuni ci sono già) sostegno agli Scanner,le stampanti e le nuove tavolette Wacom dal Design e funzioni futuristiche, grazie all'USB. :wow:
Speriamo si smuova tutto appena sarà disponibile la nuova OS4.1.1 grazie all'USB2.0 che attendo con ansia! (anche per lo svago di trasferire grossi file dalle chiavette :eheh2: )
Se avessi uno studio fotografico con un'OS4 completo di tali SW farei pure gli straordinari solo per il gusto di usarli al meglio! :boing:
Messaggioda ematech » sab lug 31, 2010 9:07 pm
io rivoglio octamed !
3 Amiga 1200 base
ematech
Messaggioda cip060 » sab lug 31, 2010 9:49 pm
che figata sti programmi :ultralol:
Messaggioda amig4be » lun feb 28, 2011 6:22 pm
scusate ma un bel Xaos, frattali?
http://wmi.math.u-szeged.hu/xaos/doku.p ... eries:main
è il più impressionante programma per esplorare i frattali che ho mai visto, a parte che fila liscio anche su computer del 15/18, dovrebbe andare di lusso sui pmac... ma ho visto con il cerca che è già stato portato su amigaos(e qui malcagatissimo), versione mos?
ci si puà fare con i filtri delle animazioni impressionanti e poi riciclarle
-Rinascita parte II (54 Pg)
-Rinascita Parte III (12 Pg)
-Aspettando la parte IV
Oppure si vai qui:
amig4be
Messaggioda cip060 » lun feb 28, 2011 6:31 pm
E'Uguale e Zone explorer su MOS :ultralol:
Hai mai usato Zone Explorer?? generatore di frattali nato su amiga 68K e portato su MOS fin dalla versione 0 di MOS dalla stramitica Elena Novaretti(veramente lo ha creato lei) :ride:
Messaggioda amig4be » lun feb 28, 2011 6:38 pm
no però recentemente mi serviva una sequenza frattale e ho trovato questo programma, guarda prova a scaricare se c'è una versione mac e sul mini dovrebbe decollare, figurati che l'ho trovato incredibilmente veloce anche su un duron 800 mezzo sfondato del 2001... in pratica è figlio diretto di tutte le migliori ottimizzazioni nate sulla visualizzazione dei frattali quando si smanettva nell'epoca doro (anni 90) con i pochi megahertz, e in presenza di gigahertz fa paura.
Oppure si vai qui:
amig4be
Messaggioda Mabo81 » lun feb 28, 2011 6:39 pm
io voglio offis, pauer punto, icicu ed anche scaip non sarebbe male :ammicca:
Mabo81
Messaggioda Varthall » lun feb 28, 2011 6:58 pm
Raffaele ha scritto:Segnalo questo programma per fare foto panoramiche, partendo da tante foto di base, per poi unirle in un'unico file immagine panoramico:
Per OS4 c'e' ALE che fa esattamente questo, anche se e' solo a riga di comando:
http://os4depot.net/index.php?function=showfile&file=graphics/misc/ale.lha
Varthall
Varthall
Messaggioda cip060 » lun feb 28, 2011 7:02 pm
Anche Zone explorer funziona su os4 mi pare di ricordare :ride:
Messaggioda ematech » gio apr 04, 2013 12:21 am
se qualcuno vuole portare live touch xj ben venga www.livetouchxj.com, non mi sembra complicato, ho fatto anche i suoni originali
3 Amiga 1200 base
ematech
Messaggioda tlosm » gio apr 04, 2013 12:29 am
Io suggerisco qemu che è il core anche di virtualbox... se si riuscisse a far utilizzare i ppc non in emulazione ma in virtualizzazione e i videofb si riuscirebbe ipoteticamente a usare macosx su os4 come amicygnix :)
Messaggioda Mabo81 » lun apr 15, 2013 5:46 pm
Io propongo se qualcuno vuole sbattersi per i driver del Mac mini (PowerPC) AirPort
saluti :tie:
Per me cip060 ce la può fare :sburla:
Mabo81
Messaggioda cip060 » lun apr 15, 2013 6:34 pm
La apple non rilascia le specifiche e quindi sai dove te lo puoi mettere in ogni caso le chiavette wifi funzionano gia
