WinUAE 3.3.x Beta Series Development
Re: WinUAE 3.3.x Beta Series Development
Messaggioda AMIGASYSTEM » sab apr 30, 2016 7:53 pm
WinUAE 3.3.0 Beta 12 (30 Aprile 2016)
WinUAE 3.3.0 Beta 12 (64Bit) (30 Aprile 2016)
- Dummy 68030 MMU instructions were also accidentally disabled in "generic" 680x0 core. (b11)
- AGA mode HAM6 colors were not 100% accurate. (Was fixed in b11)
- Stop with HALT10 if compatible CPU is not ticked and exception begins with SSP pointing to non-existing address space.
- Prevent programmed mode display width and height to become too small. Program doing something very stupid or crashing program can write very random values to programmable refresh rate custom registers.
- Switching Advanced chipset compatible option off and then back on does not anymore reset chipset extra back to Generic in non-quickstart mode.
- 1M/512k+512k Advanced chipset option was not reset when Advanced chipset was in compatibility mode.
- A3000 SCSI + any WD based Z2 SCSI controller: autoconfig didn't work.
Messaggioda AMIGASYSTEM » dom mag 15, 2016 7:03 am
WinUAE 3.3.0 Beta 13 (14 Maggio 2016)
WinUAE 3.3.0 Beta 13 (64Bit) (14 Maggio 2016)
- HALT10 was incorrectly triggered in some configurations (b12)
- Update ExecBase.MaxLocMem (and ChkSum) if more than 2M chip RAM is configured.
- It was not possible to fully disable enabled expansion device without restart. Checkbox was unticked but device was not fully disabled.
- Copper COPJMP blitter conflict bug emulation is again disabled (Breaks Batman Vuelve / Batman Group). There is still something unknown. I did some more tests and some blitter cycle sequences do not conflict with buggy copper cycle and correctly wait one extra cycle.
- Added IVS Trumpcard Pro/GrandSlam SCSI v4.9 ROM image. Emulation not yet implemented. "Trumpcard Professional Driver 4.9 - devs/IVS_SCSIpro.driver IVSSCSI 4.9 (20 Sep 1991)"'
Variable Refresh rate updates. I finally bought G-Sync monitor, Acer Predator X34. Every emulator (any emulator!) user should get G-Sync or FreeSync hardware because variable sync has all the advantages of vsync without any vsync disadvantages!)
- Adaptive Sync renamed to Variable Sync. Adaptive Sync is name of DP variable refresh rate standard (which AMD's FreeSync is based on). "Official" generic name is Variable Refresh Rates but Variable Sync fits better with other VSync modes in GUI.
- Variable sync + black frame insertion is now supported in windowed and full-window mode. (I couldn't get G-Sync to work in normal windowed mode but it did work in full-window)
- Variable sync + black frame insertion is now supported in RTG modes.
- Black frame insertion is not enabled in variable sync mode if refresh rate would become larger than selected display refresh rate (fullscreen) or desktop refresh rate (windowed/full-window).
- Variable sync + black frame insertion and if doubled refresh rate is equal to selected/max hardware supported refresh rate: automatically reduce internal emulated refresh rate by 0.5Hz to guarantee glitch free display. (Workaround for monitors that have max refresh rate of 100Hz=PAL or 120Hz=NTSC)
Ultima modifica di AMIGASYSTEM il ven mag 20, 2016 7:18 am, modificato 1 volta in totale.
Messaggioda AMIGASYSTEM » ven mag 20, 2016 7:14 am
WinUAE 3.3.0 Beta 14 (18 Maggio 2016)
WinUAE 3.3.0 Beta 14 (64Bit) (18 Maggio 2016)
- AGA subpixel scrolling: if line's parameters didn't change compared to previous field's line, line was not marked as "changed" and was not always redrawn correctly. (Roketz scoreboard corruption)
- CD32: always generate subchannel interrupts and transfer subchannel frames when reading CD sectors if subchannel DMA channel is enabled. (Previously was only done when playing CD audio) Real hardware also transfer subchannel frames when CD is idle. This is not yet emulated.
- Added "Paste" input event (END+INSERT default mapping), injects host clipboard text content using emulated keyboard key codes. Only available when clipboard sharing is not active and only supports ROM default US keyboard layout. For example can be used to paste strings directly to boot CLI, hardware debuggers or non-AmigaOS operating systems.
- Mouse/joystick autoswitching broke some betas ago.
- Pause/GUI + black frame insertion: don't show black frame.
- IVS Trumpcard Pro/GrandSlam SCSI emulation implemented.
- AROS ROM updated.
- Few weeks ago released new MSVC optimizer enabled (May not have it enabled in final version because it is not yet fully production ready). Report if you notice any performance improvements.
IVS Trumpcard Pro/GrandSlam SCSI:
- Autoboot, seems to support custom filesystems.
- 5380 based.
- Fake DMA. Long reads, word wide writes.
- "Trumpcard Professional Driver 4.9 - devs/IVS_SCSIpro.driver IVSSCSI 4.9 (20 Sep 1991)"
Messaggioda AMIGASYSTEM » mar mag 24, 2016 7:30 pm
WinUAE 3.3.0 Beta 15 (24 Maggio 2016)
WinUAE 3.3.0 Beta 15 (64Bit) (24 Maggio 2016)
- Remove unmatched characters from keyboard injected paste event. (Previously was replaced with spaces).
- Delay each paste injected key press and release a bit. Some programs don't like too fast key events.
- Restoring statefile with blitter active and it was force-finished (=not cycle-exact mode): blitter interrupt was not correctly generated when restoring state file.
- Fixed Direct3D mode DirectX9 install warning buffer overflow.
- Added "ROM disabled" to ROM panel Boot ROM selection. "ROM disabled" = force disable UAE boot ROM even if one or more UAE expansions are configured.
Messaggioda AMIGASYSTEM » dom mag 29, 2016 12:23 pm
WinUAE 3.3.0 Beta 16 (28 Maggio 2016)
WinUAE 3.3.0 Beta 16 (64Bit) (28 Maggio 2016)
- Replaced obsolete Logitech LCD API usage with current version. No other changes, still plain black and white only.
- Fixed IDE emulation corner case when polling (not using interrupt) BSY bit.
- Changing GUI relative path mode immediately updates paths stored in registry. (Older WinUAE versions don't understand relative paths in registry, switch off relative mode if you use old versions)
- Fixed directory filesystem slowdown introduced when it was converted to OS4 compatible trap system (b3).
- Replaced obsoleted _wpgmptr with GetModuleFileName()
Messaggioda AMIGASYSTEM » mer giu 01, 2016 8:00 pm
WinUAE 3.3.0 Beta 17 (30 Maggio 2016)
WinUAE 3.3.0 Beta 17 (64Bit) 30 Maggio 2016)
(3.3.0: forse ultima o penultima beta)
- Pre-KS1.3 boot hack code and data was overwritten by new resident structure update in b4.
- PlanarToDirect RTG optimization fixed. (b16 included forgotten borken version).
Messaggioda AMIGASYSTEM » lun giu 06, 2016 3:00 pm
WinUAE 3.3.0 Beta 18 (3 Giugno 2016)
WinUAE 3.3.0 Beta 18 (64Bit) 3 Giugno 2016)
- "ROM needs 68020+" dialog repeated forever.
- Fall back to old GDI screenshot method if GetRenderTarget() fails.
- Logitech color LCDs work again, old API did the conversion automatically.
- Fixed UAE boot ROM trap code corruption if "too many" UAE expansions were enabled. (b3)
Messaggioda AMIGASYSTEM » mer giu 08, 2016 8:54 pm
Versione Ufficiale di WinUAE 3.3.0 (Stabile), queste le nuove caratteristiche:
- New optional "indirect" UAE expansion trap system, fully compatible with OS 4.x, virtual memory and some debugging programs.
- PC Bridgeboard disk drive raw image support. (ipf, ext adf,...)
- Monochrome video out emulation, including A1000 color/mono video out software control (BPLCON0 COLOR bit).
- Dark palette fix option to correct colors of badly ported Atari ST games (Midnight Resistance etc..)
- Official CSPPC/BPPC flash updater can be used to install full ROM image without having existing ROM image file.
- Custom input events can execute Amiga-side commands and scripts.
- Windows clipboard to emulated Amiga keyboard paste support.
- Variable refresh rate optimized vsync mode (G-Sync/FreeSync).
- Black frame injection is supported in variable refresh modes.
- IVS Trumpcard Pro/GrandSlam SCSI emulation.
OS4.x supported UAE expansions:
- Directory harddrives, including on the fly insertion/removal.
- CDFS CD mounting.
- Clipboard sharing.
- uaegfx RTG.
- uaehf.device hardfiles.
- Virtual mouse driver/magic mouse/tablet mode.
- uaenet.device.
- uaeserial.device.
- uaescsi.device.
- uae.resource.
- uaenative.library.
Thanks to all who donated.
NOTE: Performance is not (and can't be) as fast as with m68k AmigaOS, especially with directory harddrives, due to slower, much more complex UAE to/from native code context switch trap system.
Updates:
- Game Ports panel input customization is finally very intuitive.
- On the fly input device insertion/removal improvements.
- Many input device handling updates and fixes.
- Faster screenshot/capture in after filtering mode.
- Continuous screenshot mode.
- CD32 Akiko chip low level emulation compatibility improved.
- Nero .nrg CD image support.
Bug fixes:
- Hardware RTG emulation rendered same frame twice in some situations causing slow performance.
- Amithlon partition type (0x78/0x30) support works again.
- Some storage devices failed to mount as a harddrive.
- AGA subpixel scrolling glitches.
- Miscellaneous custom chipset emulation fixes.
- Some programmed custom chipset display modes crashed.
- Direct3D mode DirectX9 not installed warning corrupted memory.
- Fullscreen + paused + enter GUI: GUI was invisible.
- Display panel gamma value calculation fixed.
- CDFS automount didn't mount CDs with empty label.
Visitano il forum: Majestic-12 [Bot] e 6 ospiti
