Re: Updates Amiga OS 3.5/3.9 Con 3.1.4
Messaggioda scusscus » dom set 30, 2018 8:43 pm
E' ufficiale AmigaOS 3.1.4 for 68K a € 29,95 !! :annu: :wow:
Annuncio: http://hyperion-entertainment.biz/
Download: http://hyperion-entertainment.biz/index ... migaos-314
Ultima modifica di scusscus il dom set 30, 2018 8:45 pm, modificato 1 volta in totale.
scusscus
Messaggioda scusscus » dom set 30, 2018 8:45 pm
Some highlights:
Over 20 Kickstart ROM modules and many more disk-based core OS components were fixed, updated, or added.
Native support for all Motorola 68000-68060 CPUs, and a more robust Auto-Configuration process.
Support for large hard disks, including boot, for any OS 2.x/3.x-compliant controller driver supporting HD_SCSI_CMD, TD_64 and/or NSD. Dedicated boot partitions are a thing of the past, even on legacy devices. You can also use variably-sized "super floppies".
A modernized Workbench as powerful as the OS 3.9 version, including new or refreshed Preference editors in the legacy OS 3.1-"GadTools" style. Its tools such as DiskCopy and Format fully support large media.
Printer, hard disk and many other support tools have been fixed and upgraded.
Remember "Diskdoctor"? It earned its PhD and is now ready to reliably rescue data from your floppies or hard disks.
The CLI/Shell and many of its commands have been reworked and modernized, now sporting native support for pipes, softlinks, hardlinks and long filenames. New commands support running Workbench programs from the Shell or upgrading ROM modules.
CrossDOS and the CD-ROM filesystem are now smarter, faster, and multi-threaded, adding Rockridge and Joliet extensions as well as UDF.
Fully reworked, modernized and bug-fixed printer drivers include support for PCL and PostScript, along with legacy NEC and Epson printers.
An optional upgradeable intuition.library provides off-screen dragging of windows for native and P96 RTG screens.
A colorful, professionally designed icon set is included, along with the traditional four-color icons.
scusscus
Messaggioda AMIGASYSTEM » dom set 30, 2018 9:19 pm
DanyPPC ha scritto:Grazie, ma è sempre ufficiale ?
Se è ufficiale il BoingBags 3&4 v1.43 dal link fornito da te lo sarà anche il BoingBags 3&4 v1.437 del link postato da me, come puoi vedere dallo screenshot entrambi i ReadMe riportano le stesse fonti e gli stessi autori, naturalmente tra le due versioni ci sono poche differenze oltre a contenere alcuni file già un po' vecchiotti rispetto a quelli più freschi recensiti da me in questi utimi mesi su questo portale.
Immagine - AfA One - AfA One PPC - AROS One x86 - AROS One 68K - WinUAE OS 4.1 -
Messaggioda cip060 » dom set 30, 2018 9:32 pm
E' Ufficialmente stato rilasciato 3.1.4
costa 29 euro
Carrol Shelby
STEVE JOBS
Messaggioda schiumacal » dom set 30, 2018 9:39 pm
Ragazzi ma mi fate capire di preciso di cosa stiamo parlando ?
Perchè si chiama AmigaOS 3.1.4 ?
E chi come me ha AmigaOS 3.9 perfettamente aggiornato, cosa serve passare a questo amigaOS che dai numeri di serie sembra riportare indietro di versione...
Francamente non mi è chiara la situazione...
Fatemi capire bene, perchè inizio a non seguire più agevolmente la situazione Amiga, e siccome ci programmo vorrei non perdermi con variazioni di sistema che potrebbero diventare obsolete, e magari seguire anche per il futuro una strada sbagliata.
Messaggioda AMIGASYSTEM » dom set 30, 2018 10:13 pm
Allora AmigaOS 3.1.4 dovrebbe aggiornare tutti gli OS a partire dal 3.0 fixando e migliorando alcuni aspetti del Sistema Operativo QUI puoi leggere una piccola recensione da parte di uno sviluppatore, mentre QUI risponde ad una mia richiesta similare alla tua, per maggiori informazioni e per avere le idee più chiare dovresti leggere tutta la discussione.
Questo aggiornamento credo sia più utile per chi usa un AMiGA Reale, su un AMiGA Emulato eccetto i nuovi File di Sistema, le nuove Librerie o Device etc.. il resto dovrebbe essere già disponibile nelle opzioni di WinUAE, per esempio la gestione dei CD, dimensione e gestione Hardisk etc..
A detta dai primi acquirenti il pacchetto comprende "ROM image + 7 image ADF"
Messaggioda Dr_Procton » dom set 30, 2018 11:10 pm
Io l'ho appena acquistato (versione amiga 1200). Confermo che il pacchetto contiene 7 adf (Install3_1_4 - workbench3_1_4 - Storage3_1_4 - Extras3_1_4 - Locale - Fonts - ModulesA1290_.3.1.4 ), ed una cartella ROMs contenente sia le due rom da imprimere nei chip che una rom singola da usare con gli emulatori o le funzioni maprom delle schede blizzard o vampire.
Sembra quindi che i floppy locale e fonts non siano cambiati rispetto al 3.1 e che probabilmente il floppy aggiuntivo serva per chi deciderà di installare il sistema con le normali rom 3.1. Non ho ancora deciso cosa farne esattamente (aggiornare il 3.9 o installare da zero un sistema 3.1.4), ma probabilmente per capire di cosa si tratta sarebbe meglio provare a fare un install da zero. Appena ho modo lo provo (magari ci faccio un video)
Dr_Procton
Messaggioda cip060 » dom set 30, 2018 11:33 pm
Ho visto le foto e vedo interessante la possibilita del riconoscimento automatico di hardisk superiori a tot giga senza tanti sbattimenti vari!!
Quindi nativo diciamo con presumo patch della scsi device
Per caso e' gia dentro PFS AIO ?mi servirebbe per il cd32 quindi versione 1200 presumo
Carrol Shelby
STEVE JOBS
Messaggioda DanyPPC » dom set 30, 2018 11:37 pm
Appena comprato, ma non capisco se posso installarlo sopra i vari Boing Bag 4 inufficiosi o se devo retrocedere ad una installazione pulita del 3.9 BB2.
Farò delle prove su WinUAE e poi proverò a vedere le differenze con l'attuale installazione del 3.9 BB4.
Ho visto che hanno cambiato le icone, più stile OS4 e nell'archivio, oltre il file kickstart da usare via software ci sono i 2 bin low and high da flashare su eproms reali, per avere il kickstart direttamente in hardware, in attesa che lo rilascino fisicamente ai rivenditori Amiga.
Comunque, tutto da testare nei prossimi giorni.
A1200 OS3.0 2MB
A600 OS2.0 1MB/Gotek Drive
DanyPPC
Messaggioda marmotta » dom set 30, 2018 11:38 pm
Dr_Procton ha scritto:Io l'ho appena acquistato (versione amiga 1200). Confermo che il pacchetto contiene 7 adf (Install3_1_4 - workbench3_1_4 - Storage3_1_4 - Extras3_1_4 - Locale - Fonts - ModulesA1290_.3.1.4 ), ed una cartella ROMs contenente sia le due rom da imprimere nei chip che una rom singola da usare con gli emulatori o le funzioni maprom delle schede blizzard o vampire.
Non ho capito la questione ROM.... non ti danno i chip? Uno deve avere le eprom vuote ed il programmatore per scriverle? :sperduto:
Messaggioda Dr_Procton » dom set 30, 2018 11:39 pm
Non credo ci sia il pfs. Credo abbiano aggiornato il fsf.
Se ho capito bene suppongo che x chi vuole i chip/floppy ci sarà una distribuzione fisica a breve
Dr_Procton
Messaggioda cip060 » dom set 30, 2018 11:49 pm
Alcuni punti salienti:
Sono stati riparati, aggiornati o aggiunti oltre 20 moduli Kickstart ROM e molti altri componenti principali del sistema operativo basati su disco.
Supporto nativo per tutte le CPU Motorola 68000-68060 e un processo di configurazione automatica più robusto.
Supporto per dischi rigidi di grandi dimensioni, incluso l'avvio, per qualsiasi driver del controller conforme a OS 2.x / 3.x che supporta HD_SCSI_CMD, TD_64 e / o NSD. Le partizioni di avvio dedicate sono un ricordo del passato, anche su dispositivi legacy. Puoi anche usare "super-floppies" di dimensioni variabili.
Un workbench modernizzato potente come la versione OS 3.9, compresi gli editor di preferenze nuovi o aggiornati nello stile legacy di OS 3.1- "GadTools". I suoi strumenti come DiskCopy e Format supportano completamente supporti di grandi dimensioni. Stampante, disco rigido e molti altri strumenti di supporto sono stati risolti e aggiornati.
Ricorda "Diskdoctor"? Ha conseguito il dottorato di ricerca e ora è pronto a salvare in modo affidabile i dati dai propri floppy o dischi rigidi.
La CLI / Shell e molti dei suoi comandi sono stati rielaborati e modernizzati, ora offrono supporto nativo per pipe, softlink, hardlink e nomi di file lunghi. Nuovi comandi supportano l'esecuzione di programmi Workbench da Shell o l'aggiornamento di moduli ROM.
CrossDOS e il filesystem del CD-ROM sono ora più intelligenti, veloci e multi-thread, aggiungendo estensioni Rockridge e Joliet e UDF.
I driver di stampa completamente rielaborati, modernizzati e corretti da bug includono il supporto per PCL e PostScript, insieme alle stampanti legacy NEC e Epson.
Un intuition.library aggiornabile opzionale fornisce il trascinamento fuori schermo di Windows per gli schermi RTG nativi e P96.
Un set di icone colorate e dal design professionale è incluso, insieme alle tradizionali icone a quattro colori.
Carrol Shelby
STEVE JOBS
Messaggioda AMIGASYSTEM » lun ott 01, 2018 12:40 am
QUI sempre su eab.abime c'è una nuova discussione dedicata a OS 3.1.4 dove è possibile trovare altre info e alcuni screenshot che mostrano il nuovo Workbench e le nuove icone, in uno screenshot il File system Maintenance mostra l'installazione del File System International (FFS).
Messaggioda cip060 » lun ott 01, 2018 12:49 am
Ovviamente ci vuole il disco originale 3.1.4 per fare update dal file di aminet lo richiede :ride:
Carrol Shelby
STEVE JOBS
Messaggioda cip060 » lun ott 01, 2018 1:24 am
Al momento no funziona anche con il 3.1!
Si ci sono i file.bin delle rom pronti per essere flashati avendo programmatore ed eprom!
Carrol Shelby
STEVE JOBS
