Nuove versioni software da OnyxSoft
Messaggioda AMIGATV » sab dic 01, 2007 1:42 pm
Dopo l'uscita dell'os4 per i classici la OnyxSoft ha rilasciato 5 aggiornamenti dei loro software.L'aggiornamenti riguardano le versioni 68k, il tutto funziona al 100% sull'os4.
Ecco le novità:
BackUp v1.50 - (68k) Backup program that mirrors a directory structure. Added more parameters to use BackUp from CLI. BackUp can now follow links, or ignore links completely.
TheMPegEncGUI v2.65 - (68k) Full-featured GUI for MP3-encoders and more. Added support for faad - AAC/MP4 audio decoder. Updated italian translation. Fixed a bug with long ID3 strings.
DagensTV v1.42 - (68k) Program for comfortable viewing and get reminded about TV-programs received on e-mail. It was long since this got updated but www.dagenstv.com changed format of their e-mails, hence this update.
JoinSplitter v1.32 - (68k) Split and join files with a GUI. Fixed a bug when adding files to the join list using drag'n'drop.
DigiConverter v1.4 - (68k) Developer tool to convert between decimal, hex, binary, float and ASCII. Fixed the decimal field making it able to take numbers lower than -999999999.
http://www.onyxsoft.se/
Messaggioda Danyblu » sab dic 01, 2007 1:51 pm
Ma quante belle cose nuoveeee..... :ride: Mi sa che oggi pome o al massimo Luned' faccio qualche acquisto
http://www.a-n-i-m-a.com
http://www.hobbyeu.it
Danyblu
Messaggioda Amiga Supremo » sab dic 01, 2007 1:54 pm
Scegli bene quello che vorresti acquistare. :ammicca: :ahah:
